"Help" Error
Homer712
Experienced
Experienced
"Help" Error
Post by Homer712 »
Every time I try to select the "Help" menu item, this is the result (I've reinstalled SyncBack Pro twice, no help):
Re: "Help" Error
Post by Kostas »
Can you please tell us which version of SyncBackPro you are using plus the version of your Windows and the version of Internet Explorer?
Homer712
Experienced
Experienced
Re: "Help" Error
Post by Homer712 »
Kostas,
Problem solved. Rather than reinstalling SyncBack Pro (V8.0.1.0, 64 bit) I should have first tried the "Solves Most Windows Issues" fix, a reboot. Help is back functioning just fine.
