Failed to copy from Source : nameAlreadyExists: The specified item name already exists.
mwthrane
Post by mwthrane »
Upgraded to V8.. Why is this happening? If it exists just skip it im thinking..? Dont bother me with it.
Recv 05-06-2017 17:27:44: 0
ParseLastResponseError: {"error":{"code":"nameAlreadyExists","message":"The specified item name already exists."}}
ParseResponseError: The specified item name already exists., nameAlreadyExists
[E] IsRateLimited - Exception = "HTTP/1.1 409 Conflict" - ClassName = "EIdHTTPProtocolException"
[E] IsRateLimited - Error Message = "{"error":{"code":"nameAlreadyExists","message":"The specified item name already exists."}}" - Error Code = "409"
[E] IsRateLimited: NO
Upload exception: HTTP/1.1 409 Conflict
What to do?
mwthrane
Re: Failed to copy from Source : nameAlreadyExists: The specified item name already exists.
Post by mwthrane »
And no the file does not exist twice on source.
DocRD
Post by DocRD »
Hello mwthrane,
can you please post a screenshot from the "simple" (source/destination) form ?
Lg Kai
mwthrane
Post by mwthrane »
mwthrane
Post by mwthrane »
http://imgur.com/a/fU6OE
ïmg tag is not working,
DocRD
Post by DocRD »
Thank you for the link to the screenshot. I'm posting the screenshot here for you:
I think there is a problem with onedrive. Exists the "Veeam" folder on the onedrive storage ?
If not, please create them in onedrive and try again.
Lg Kai
mwthrane
Post by mwthrane »
Yes its there.
Post by Kostas »
mwthrane wrote:Upgraded to V8.. Why is this happening? If it exists just skip it im thinking..? Dont bother me with it.
What to do?
You'll have to generate a Support Zip with debug log for your profile and send it over to us for further investigation.
Engztrom
Experienced
Experienced
Post by Engztrom »
FYI I have the same problem, on a few but seemingly random files...
Regards,
/Mikael
