Trying out the new SyncBackPro v8.0.1.0 (x64) version against Microsoft OneDrive Personal cloud storage.
The new API seems to be able to handle the ";" invalid character issue and most other issues I had with V7,
but there are still a problem with the "%" character in filenames.
Since "%" is not listed as an invalid character with OneDrive, and from the log printout below, it looks like it is SyncBackPro
that is substituting "%3F" with "?" before sending the upload request to OneDrive, hence invalidating the filename.
Or is it a Microsoft issue?
Profile Name: D to OneDrive - media (ej filmer, dokumentärer)
Source: D:\Media
Destination: \D\Media
Cloud: Destination is on the cloud.
Compression: Each file on Destination is compressed
Unattended: Yes
Trigger: Manual
2017-06-06 03:06:17
\Bilder\Historyteacherz\Iconosquare (Amy Burvall)\Do you think they'll let me wear my surgical cap as a jaunty beret%3F [f3ac32b60a8c11e3b0f022000a9f1369_7].jpg
Error: Failed to copy from Source : invalidRequest: One or more invalid characters are present in the path (/Do you think they'll let me wear my surgical cap as a jaunty beret? [f3ac32b60a8c11e3b0f022000a9f1369_7].jpg.zip).
Not a big problem for me since I only have a few files with "%" in the filename, but if it could be fixed
without having to rename the files it would be great!
/Mikael
Issue with "%" in filenames
Re: Issue with "%" in filenames
I just did a quick test with uploading a file that had plenty of "%" characters in its name using the new API without issues. I am suspecting that your profile may be still using the old API because it was imported from V7?
If you haven't created a new profile that uses the new API or haven't upgraded your V7 profile to use the new API then I would suggest following the steps outlined in this topic: viewtopic.php?f=15&t=12884#p48886
If you are using the new API and still getting errors then you'll have to generate a Support Zip with debug log for your profile and send it over to us for further investigation.
- Experienced
No, I run the profile with the new API (i.e "Cloud Service=Onedrive (Personal)", not "Cloud Service=OneDrive (Personal) (Legacy)").
(BTW I imported the profile from V7 but had an issue with the conversion, so instead I deleted all files from the cloud storage and started over from scratch, but that's another story...)
But I have now done some more tests, and it looks like it is only the character combination "%3F" in a filename that fails, not for instance
"% " or "%31" (but I have only tried with these, so it's possible there are other combinations that will also fail).
Thank you for your help,
/Mikael
/Mikael
Ok, we've spotted the problem and we'll have a look at it.
- Experienced
/Mikael
/Mikael
We've released new betas for SyncBackPro V8, so please pick the appropriate installer depending if you are using 32 or 64 bit:
32bit: http://www.2brightsparks.com/assets/sof ... _Setup.exe
64bit: http://www.2brightsparks.com/assets/sof ... _Setup.exe
After you install it, edit your profile and under Expert -> Cloud -> Advanced clear the option "Automatically translate invalid filenames" and then run the profile.
BTW if you are experiencing conflicts while uploading, try enabling the option "Do not use the delta API (see help file)" under the same settings page and see if that helps.
- Experienced
The filename issue seems to be resolved with the new option "Automatically translate invalid filenames" disabled in the beta version,
but the delta API now thinks all my 48000+ files are different every time the profile is aborted and restarted!
However, if "Do not use the Delta API" is enabled then it copies incrementally again, but only files that
have been copied with the new beta version.
All files that were copied with the old V8.0.1.0 version are still treated as different.
Looks like the beta needs some fine tuning, but as long as I avoid delta API it works good enough for me!
/Mikael
/Mikael
