no differences found?
allitnils
Post by allitnils »
i'm trying to use syncback pro to sync files between a file server, and a sharepoint shared directory.
i'm using the network connection details for the "source" (my sharepoint share) and testing connection says 'success'.
The destination tested has been both a network share, or a file path within the same computer, ie: c:\managed\sync
The network share looks as follows:
\\path\to\server\DavWWWRoot\t111\Shared Documents\
or if using SSL:
\\path\to\[email protected]\DavWWWRoot\t111\Shared Documents\
without using ssl, i get the error "No differences found", 1 file(s) cound not be copied, deleted, or compressed. see the log file for more information.
And in the error log, Scan failed (5): Access is denied
if I AM using ssl, the simulation simply fails saying "cannot connect to source: the operation being requested was not performed because the user has not been authenticated".
can you please advise what could be going wrong? shouldn't the network connection details for source be used? i'm using under advanced, i've ticked "do not try my current username and password", so that the specified credentials are used instead.
any assistance would be greatly appreciated.
Conrad Chung
Re: no differences found?
Post by Conrad Chung »
Hi, we have responded to you in a parallel support ticket. Just a reminder, WebDAV is not supported in SyncBackPro.
However, if other users who have managed to get Pro to work with WebDAV and would like to chime in, please feel free.
