When my computer goes to sleep while performing a cloud backup, and wakes up later, the backup task stalls showing some 300 second countdown timer.
Is it possible to gracefully resume a cloud backup task even if the computer goes to sleep and wakes up during the backup?
The reason I am asking is that I want to save power and my computer will go to sleep when the electricity is expensive, then wake up again when the electricity is cheaper.
Automatic cloud backup resume after sleep?
Re: Automatic cloud backup resume after sleep?
Hi, can you post a screenshot which shows the 300 second countdown timer after your PC wakes up and the profile is about to resume?
Did you change the resume timers under Preferences menu > Options > Easy tab?
