bug in v8.1.1.0
markbelli
bug in v8.1.1.0
Post by markbelli »
For some reason versioning is not working properly.
No filters, all files included.
Just made a modification to 2 php files.
Profile log correctly registers the modification, they are copied to the backup device.
BUT they are not copied to the $SBV$ folder.
markbelli
Re: bug in v8.1.1.0
Post by markbelli »
I meant: their previous versions are not copied to the $SBV$ folder.
Re: bug in v8.1.1.0
Could you please submit a support zip (with debug logs) of your profile configuration for further investigation. Full instructions to create and submit a support zip are given here:
markbelli
Re: bug in v8.1.1.0
Post by markbelli »
my fault sorry.
No bug.
Profile had a filter to exclude files older than 30 days..
So the 1st modification of a file older than 30 days correctly did not generate the versioned copy.
Thanks anyway!
