Use Case: Keeping folders in sync.
Source folder name: "Pictures" (e.g. contains 50GB of files)
Renaming the source folder to "Pictures-01".
Target drive still has the original folder named "Pictures"
Question: During sync, will SyncBack simply rename the target folder, or will it re-copy all the same files?
Renaming Folders - Behavior during sync?
Re: Renaming Folders - Behavior during sync?
My mistake...
it's not "sync". I meant "mirror"
I just ran a test, and it appears that if I rename a folder in the source drive, it will delete the old folder (and contents) on the mirrored drive, then proceed to copy the entire (newly) renamed folder to the mirrored drive.
