Hi there!
I'm using Amazon Drive to backup my files, which works quite well. Except for 13 files. Syncback uploads them to a certain degree, but cancels it along the way with several different error messages:
HTTP/1.1 504 GATEWAY_TIMEOUT
or
Read timed out.
It's always the same 13 files, that can't be copied. Any suggestions?
Amazon Drive - Some files can't be uploaded
Re: Amazon Drive - Some files can't be uploaded
You'll have to generate a Support Zip with debug log for your profile and send it over to us for further investigation.
