Hi, Can someone help me with my backup and file distribution problem, I am trying to find a new solution to replace an existing application doing the same thing but now struggling.
I basically I would like to achieve a few things:
1. I have a source that maintains a rolling 3 days worth of logs, I would like to upload these to a 2 x cloud providers for backup and sharing. as files are deleted from the local source I would like to delete from the cloud after a further x number of days.
2. I have a second server in a different data centre where I would like to download the same log files from the cloud provider to a local folder but only download the latest x day's
Can I do this with Syncback Pro, if so how?
Thanks for your help in advance.
Help with Cloud Backup's
Re: Help with Cloud Backup's
1. You can create a Mirror profile in SyncBackPro with Source pointing to a folder where your primary data is stored, and Destination to the cloud server. Then configure the Modify > Expert > Decision-Files > What to do if a file exists on Destination but not on Source > Delete file from destination if it hasn't been modified within the last x days.
When the profile is next run, SyncBackPro will copy new/changed files from source to destination and delete destination ‘only’ files (files that are present only on destination) that have not been modified within that X number of days.
Please read the Help file > Using SyncBackPro > Basic Operations > Creating a Profile and Running a Profile for the steps to create and run your first profile. With SyncBackPro opened, press F1 to open the contextual help.
2. Create a Backup profile in SyncBackPro on the second server with Source pointing to cloud server and Destination to a folder on local drive. Then configure the setting Ignore files that [have/have not] been modified [within the last] XX [seconds/minutes/hours/days/weeks/months/years] OR [since] [calendar date] [calendar time]
under:
Modify Profile > Expert Mode > Compare Options > Date & Time settings page
to ignore older files based on their last modification date/time stamps and download the remaining files to destination. Please read the help file > Compare Options > Date & Time settings page for more details about this option.
You can also read this forum post for additional details:
viewtopic.php?t=12435&p=47561#p47561
under:
