Feature request: extended password protection
Engztrom
Experienced
Experienced
Post by Engztrom »
There is an option in SyncBackPro to password protect a profile from being changed or deleted, but you can still run it!
Consider this scenario:
Your computer gets stolen, and the thieves (assuming they are evil, which they probably are!) delete the local files on your computer,
and then (if it's a mirror) run your backup profile to also delete the files (or implant virus) on your cloud backup!
Therefore it would be great if the password protection could be extended to include ALL operations on a profile
except deleting it (since you would need a delete option if you forget the password).
Regards,
/Mikael
Re: Feature request: extended password protection
I will pass your request to the relevant department for their review and consideration.
