Hi Folks,
I have a large number of video files created by a video team I'm looking to backup.
When they initially offload the video to the server it is pretty huge - up to 80 GB ea.
The finished product is much smaller (usually under 10 GB).
I'm looking to backup the smaller files but not the larger ones. Is there a way I can add a filter based on size rather than path?
Dave
Is It Possible To Filter Files Based On Size?
Re: Is It Possible To Filter Files Based On Size?
Hi
Modify profile > Expert mode > Compare Options > File Size > bottom pair of Ignore options
F1 with File Size dialog open for contextual Help (hint; in your case you can leave the 'Ignore files less than' setting at 0 = 'no lower limit')
For the 'ignore files more than' setting, you will need to 'do the math' (multiples of 1024, etc) for large file size values. If high accuracy is required, you can specify an exact size (to nearest byte, if required), but if the wanted:unwanted files are always in the same ratio as your example, then 'ignore files more than [15,000,000,000] bytes' will probably suffice to tell them apart (if you know better. adjust accordingly)
Thanks! Very helpful!
