I am currently still on SyncBackPro V7 but have just installed V8.5.5.0 after seeing New (Pro): Support for Google Team Drives listed in the changes for V8.1.1.0 however when I set up a profile I can only access my google drive and not my google team drive.
are google team drives not supported?
thanks
Google Team Drive SyncBackPro V8.5.5.0 evaluation
Re: Google Team Drive SyncBackPro V8.5.5.0 evaluation
SyncBackPro V8 supports Google Team Drives. To backup files to/from Google Team Drive:
1. Create a new profile via Profile > New menu
2. In the 3rd screen select Google Drive as destination (or source if you want to backup files from Google Team Drive) and click on Next button
3. The ‘Cloud connection Details’ page will open. Click on the Authorize button at that page to start the authorization process. From there, you may need to follow the on-screen prompts to allow authorized access to SyncBackPro
4. Once the authorization is successful, click on ‘Refresh’ button to retrieve a list of Team Drives that your account has access to. Select the Team Drive that you want to use (from the list box) and click on ‘Done’ button
5. A profile setup window will be opened, where you can configure the Source/Destination path and other settings according to your requirement and run the profile to backup files to/from Google Team Drive.
thank you, I have upgrade my licence to Pro V8
Hi Swapna,
I am using V8.5.5.0 now and follow the step you said, but after authorized from Google, I can't see a "Refresh" button which only shows in "Google storage" service.
Please see below,
and when I switch to Google Storage, the list box shows up
But we don't have Google Storage service available.
How can we use "Google Drive" connection to access our "Google Team Drive"
Thanks.
Please see below,
Thanks.
Swapna wrote: ↑Mon Dec 11, 2017 1:23 am
Please note that the version of SyncBackPro you are using is outdated. Please download and install the latest version (V8.5.122.0) from here:
https://www.2brightsparks.com/download-syncbackpro.html
Please refer to How to Backup to Google Drive article for step-by-step instructions to create a Google Drive.
1. Once the authorization is successful, click on ‘Done’ button on the ‘Cloud Connections Details’ page.
2. A profile setup window will appear.
3. Go to Cloud page and click on ‘Refresh’ button to retrieve a list of Team Drives that your account has access to.
4. Then select the Team Drive that you want to use from the list.
Thank you, I got this fixed after updated it but not from the page I was talking.
The setting of Google Team drive is after it opened the backup detail page, go into expert setting, from the "cloud" setting on the left, I can refresh from there and get all the team drive folders.
