Hi ,
We are using Mirror profile to Copy 1000 plus files from Source (Network location) to destination (Cloud Box location) . We faced a issue as below :
There were 2 files with same name in 2 different folders but after profile run those were incorrectly copied to it’s different folders and not to their respective folders. Can you tell us why?
Is this issue fixed in Version 8
Issue in Mirror Profile
Re: Issue in Mirror Profile
Also we keep on getting below error after completion ofmirror profile run.
Failed to copy from Source : The file has been created by something else since the profile started. Please run the profile again
Please submit a support zip (with debug logs) of your profile run to [email protected] for investigation.
Hi Swapna,
Not sure if we can share the zip file. But when we click on Errors, in most of the cases below error is looged:
Failed to copy from Source : The file has been created by something else since the profile started. Please run the profile again.
Also we need to upgrade the version of Syncbackpro. Currently we are using V7.3 Could you pleas suggest which is the most stable version?
Please test with SyncBackPro V8.5.5.0 release version to see if it helps? You can download and install V8 from here:
Could you let me know if it is a 32bit or 64 bit version?
That download link is for 32-bit version. You can download 32-bit or 64-bit version from our downloads page:
https://www.2brightsparks.com/download-syncbackpro.html
If you wish to migrate from 32-bit to 64-bit version then read this KB article for more details:
http://support.2brightsparks.com/knowle ... backpro-se
Thanks for the quick reply Swapna.
