sync only when my pc is idle question
Giulia
Post by Giulia »
hi
1) can i setup a profile to run only when my pc is idle
in when -> changes -> i add these settings 600 seconds (10 minutes) and check idle , is it the right settings?
2) can i avoid a profile running when a program is active?
for example wait when firefox.exe or C:\Program Files (x86)\Mozilla Firefox\firefox.exe are not running
thanks
Giulia
Re: sync only when my pc is idle question
Post by Giulia »
hi
sadly i can edit my prev post
in short i would like
to sync when
1) source are changed
And
2) when my comptuer is idle
and
3) when a program is not working
in short AND , i need all of these events to be true
Source are changed and When my computer is idle
Please use the settings configured in the When > Changes settings page. I suggest reading the help file for additional details about ‘This must be idle computer time’ setting. With When > Changes settings page opened, press F1 to open the contextual help.
When a program is not working
Note that there is no AND relationship between When > Changes setting and When > Program setting. In other words, the profile will be executed when either condition is met.
However, you can achieve this by using the runtime script ‘WaitForFinishEx.bas’ script file in SyncBackPro profile. This script stops a profile from starting until a program has finished (or isn't running). It is available in SyncBackPro’s program folder.
1. First, you need to install the script from Preferences > Script menu
2. Then Modify the profile > Scripts > tick the runtime script ‘Wait for a program to finish before starting the profile’ from the right panel and click on Apply button
3. A new settings page ‘Wait for Finish’ will be added to the profile setup window, where you can configure the program name and the delay setting.
Then test the profile run to see if it works?
