Hi
I’m trying out syncback and in order to use the software I should be able to use the command line remotely.
At the moment I’m using psexec to launch the commands on the remote server with syncbackpro.exe only nothing is happening.
I’ve tested everything. Running a remote bat file over the psexec works fine, and also a running a bat file with some syncbakcpro command line actions are executed fine.
Only running the command line over psexec isn’t working for me.
Can someone please let me know how to get this fixed?
I've been testing this by entering: psexec \\192.168.2.120 -u user -p pw cmd
That gives me the cmd of the remote server, when navigating to the SBP folder and executing the SBP.exe with the needed commands, nothing happens.
this was the batch file I was trying to run...
cd\
cd C:\Program Files (x86)\2BrightSparks\SyncBackPro
SyncBackPro.exe -silent -delete sceneassets
timeout /t 8
SyncBackPro.exe -silent -importprofile "\\NAS\workstation\SERVER INSTALL\TOOLS\SYNCBACK PROFILES\sceneassets.sps"
timeout /t 8
SyncBackPro.exe -r sceneassets
exit
