SFTP transfer without subfolders -option not working
dumbuser
Post by dumbuser »
SFTP transfer (backup) with option: Decision - FIles -> Folders -> What do do if a directory exists on Source but not on FTP -> do nothing
still transfers folders and files inside.
I'm also running profile with UNC paths and there this option works like it should - it doesn't transfer folders or files inside these folders.
Version is 8.5.17.0. X64
Seems like a bug, or did I miss some setting?
dumbuser
Re: SFTP transfer without subfolders -option not working
Post by dumbuser »
figured it out already, had some confusion about how things/options work.
It works as it should.
