Best way to keep destination clean?
elliottmarter
Post by elliottmarter »
I have been playing around with the "delete file from dest if not in source and has not been modified in x days".
I have however realised that given this scenario
User accidentally deletes folder of work with docs that are very old but very important and doesnt tell me that day
then the data will also be removed from the backup! (because the date modified is ages ago)
How can I have it so it only removes files x amount of days after the files in the source are deleted...is that possible?
Cheers
Re: Best way to keep destination clean?
Sorry, there is no option in SyncBackPro to delete destination files X amount of days after it is deleted from Source. However, you can enable Versioning option in SyncBackPro (under: Modify > Expert > Copy/Delete > Versioning settings page) to create versions of a file before a file on your Destination is deleted, replaced or moved and save them in the $SBV$ folder within the scope of the profile's Destination path. So, you can simply restore source/destination files from version files if required. You can also configure the options 'Keep a maximum of x versions' and 'Keep versions for a maximum of x days' to specify the number of versions to keep for the maximum number of days in the same settings page.
I suggest reading the Help file for more details on Versioning. With Versioning settings page opened, press F1 to open the contextual help.
Engztrom
Experienced
Experienced
Post by Engztrom »
I have also been longing for such a feature, but realize it would be difficult to implement since there is no way to know when Windows actually deleted a certain file (I guess the Recycle Bin folder could be examined, but there is no guarantee a deleted file would be found there).
However, an easy way for the developers to implement such a feature (or at least something similar) would be an option to
"Delete file from target X days after SyncBack first detected that it was deleted from source".
That way you would at least get a minimum amount of days until the file is actually deleted, depending on how often you run SyncBack...
I will pass your request to the relevant department for their review.
