Failed backup - extended system attributes
gswarbrick
Post by gswarbrick »
Doing a big-ish backup (sync) between two Drobos and most of it's going well but about 6000 files have failed to copy with the message "The mounted file system does not support extended attributes". One of the two identical file systems clearly does... Any ideas?
Re: Failed backup - extended system attributes
Please submit a support zip (with debug logs) of the profile run to [email protected] for investigation.
