We are using SyncBackPro 8 and would like to export a list of filenames from a cloud folder scan or FTP scan to a CSV file.
Any ideas how (if?) we could do this?
Export List of Files?
Re: Export List of Files?
To export source and destination filenames to a CSV file:
1. Run the profile in manual mode (ctrl + R)
2. When the Differences Window is displayed, select 'Export All' from the Export menu and save the CSV file
Thanks for the info. Is there any way to automate this process? IE - We'd like to schedule the generation of a file list and email it periodically?
Sorry, not supported. I will pass your request to the relevant department for their review, but we can't guarantee the implementation of this feature or its implementation in a certain time frame.
