I have setup a job between SBP and SBT to run only during workdays, starting at 9 and repeating every hour for 9 hours. However, it runs every hour, but all the time: after 9pm, and during weekend. I am attaching my scheduling settings. Please someone help, it is not end of the world, but why isn't it working.
https://imgur.com/a/RqE8X
Simple help with scheduling
Re: Simple help with scheduling
Can you please export and send your profile configuration to [email protected] for investigation.
the file "Test for diagnosis.sps" was submitted
Thank you swapna
Thank you swapna
Swapna helped me address the problem via email after analyzing the profile. For those interested:
Under profile settings, under When > Periodically settings page
I had a checkbox "run every hour", and that what was running every hour
Thank you for the resolution Swapna, at times it is as easy as checkbox.
