1/2 schedule not running
studio3d
Post by studio3d »
I imported some schedules from older Syncback, and re-started 2 of them. One runs fine everyday, the other only runs manually (even though it's on the schedule as the other is. Screenshot is here https://www.screencast.com/t/6tpgFtUomo
How do I find the problem? thanks
Re: 1/2 schedule not running
Please note that we do not have a scheduler in SyncBack. We rely on Windows Task Scheduler (WTS) to trigger our program on the scheduled date/time to run the tasks. Therefore, the Task Scheduler on your system is responsible for calling SyncBackPro to run the task at the schedule date/time, but if WTS fails (for whatever reason), then the profile won't run at the schedule date/time.
Can you please delete and recreate the schedule task that failed to run from:
Modify profile > When > Edit Schedule settings page
to see if it works?
studio3d
Post by studio3d »
Thanks... I just set up a new backup and it works fine.
