Parse Errors uploading to Google Drive
Tyree
Knowledgeable
Knowledgeable
Post by Tyree »
Out of the thousands of files I have uploaded over the past month to Google Drive, there have been a handful of files that persistently throw the same error when being uploaded: Failed to copy from Source : parseError: Parse Error
If I run the same profile over and over the exact same file(s) will always throw the error. So far I have just made sure the file was uploaded and then excluded that file from the profile. Not a great solution, but it eliminates the profile constantly failing.
Below is the full error. Any idea why this is happening? Thanks!
Code: Select all
Stat Disconnected.
Stat Connected.
Sent 3/21/2018 4:22:25 PM: POST /drive/v2/files/1z-5XI2le24k9fXzkhuKt8CNPGNYqqyBO/trash?supportsTeamDrives=true HTTP/1.0
Content-Type: application/json; charset=UTF-8
Content-Length: 0
Authorization: Bearer <--Omitted-->
Host: www.googleapis.com
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
User-Agent: Mozilla/3.0 (compatible; Indy Library)
Recv 3/21/2018 4:22:26 PM: HTTP/1.0 200 OK
Cache-Control: no-cache, no-store, max-age=0, must-revalidate
Pragma: no-cache
Expires: Mon, 01 Jan 1990 00:00:00 GMT
Date: Wed, 21 Mar 2018 20:22:26 GMT
Vary: X-Origin
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
Server: GSE
Alt-Svc: hq=":443"; ma=2592000; quic=51303432; quic=51303431; quic=51303339; quic=51303335,quic=":443"; ma=2592000; v="42,41,39,35"
Acce
Recv 3/21/2018 4:22:26 PM: /jpeg", "description": "File name \t:DSC_0036.JPG\r\nFile size \t:638.3KB(653579Bytes)\r\nDate taken \t:2099/06/26 12:00:43\r\nImage size \t:2000 x 1312\r\nResolution \t:300 x 300 dpi\r\nNumber of bits \t:8bit/channel\r\nProtection attribute \t:Off\r\nHide Attribute \t:Off\r\nCamera ID \t:N/A\r\nCamera \t:NIKON D1H\r\nQuality mode \t:NORMAL\r\nMetering mode \t:Matrix\r\nExpos
Recv 3/21/2018 4:22:26 PM: 0:22:26.419Z", "modifiedByMeDate": "2018-03-21T20:22:26.419Z", "lastViewedByMeDate": "2018-03-21T20:22:26.419Z", "markedViewedByMeDate": "1970-01-01T00:00:00.000Z", "version": "5", "parents": [ { "kind": "drive#parentReference", "id": "1RloD3CO9Z0BW4OAR4kVCj6nEqLTcC0H3", "selfLink": "https://www.googleapis.com/drive/v2/files/1z-5XI2le24k9fXzkhuKt8CNPGNYqqyBO/parents/1RloD3CO9Z0BW4OAR4kVCj6nEqLTcC0H3", "parentLink": "https://www.googleapis.com/drive/v2/files/1R
Recv 3/21/2018 4:22:26 PM: icture": { "url": "https://lh4.googleusercontent.com/-cLTvh1yVkM8/AAAAAAAAAAI/AAAAAAAAADo/UiqbmOlmKaI/s64/photo.jpg" }, "isAuthenticatedUser": true, "permissionId": "<--Omitted-->", "emailAddress": "[email protected]" } ], "lastModifyingUserName": "Matt Tyree", "lastModifyingUser": { "kind": "drive#user", "displayName": "Matt Tyree", "picture": { "url": "https://lh4.googleusercontent.com/-cLTvh1yVkM8/AAAAAAAAAAI/AAAAAAAAADo/UiqbmOlmKaI/s64
Stat Disconnected.
Re: Parse Errors uploading to Google Drive
Please submit a support zip (with debug logs) of your profile run to [email protected] for investigation.
