SyncbackPro want to delete target
After updating to latest release, i have problems with intelligent sync. When i start the process, it reads both folders, but it says that target folder is empty, and then it want to delete all files in source. I have tried several new profiles, and altso tried to sync against one drive for business, but still the same.
Re: SyncbackPro want to delete target
Please submit a support zip with debug logs of the scan phase for further investigation. To do this, enable 'Output debug information' from Preferences menu and run the profile in manual mode (ctrl + R). When the Differences Window is displayed abort the profile run and submit the support zip as per the instructions given here:
