We get random fails on some large files when uploading to AWS s3
- our network has no issues at these times
- file sizes are 20 G and 32G
- sometimes they upload, sometimes they don't. The job runs every two days
- in 30 days we had this error on 11 occasions with 3 files
"Failed to copy from Source : Cloud error 200: HTTP/1.1 200 OK - The list of parts was not in ascending order. Parts must be ordered by part number. (InvalidPartOrder) - Recv 10/04/2018 07:01:47: 27, <?xml version=""1.0"" encoding=""UTF-8""?>
Why should the ordering be effected so frequently? Is there a fix?
Alex
Error for large files to s3
Re: Error for large files to s3
Please submit a support zip with debug logs of the profile run for further investigation. To do this, enable 'Output debug information' from Preferences menu and run the profile. Then submit a support zip as per the instructions given here:
