Amazon Drive
hartlenb
Amazon Drive
Post by hartlenb »
I'm running SBP v7.12.12.0. About six weeks ago, my download from Amazon stopped working (scheduled jobs never completed, blew through almost 2TB of download data). I disabled the profile as I didn't have time to look at the problem until today.
- there's no issue with downloading from Amazon Drive directly (500MB in seconds)
- Syncback is able to complete simulations of the profiles without issue
- Running the same profile live shows bandwidth varying in Bps and Kps ranges. I let the profile run for 30 mins before cancelling... unable to download two jpg that are collectively just over 2MBs.
Thanks in advance for any assistance...
My Cloud->Advanced settings for the profile are (and have been) as shown below:
(btw - I did try to search on "Amazon Drive" but apparently these words are ignored because they are too common ???)
SBP Amazon Drive Settings.JPG (84.69 KiB) Viewed 2270 times
Re: Amazon Drive
Unfortunately, technical support and updates for Pro V7 is officially ended on December 1st 2017. You can refer to our support policy here:
http://support.2brightsparks.com/knowle ... ort-policy
If you wish you can evaluate SyncBackPro V8 which we offer a free 30-days evaluation period to see if it resolves your issue. Before you upgrade to SyncBack V7, please read the last section of this article (Re: "I am using V5/V6 but would like to try V7....") to backup a copy of your profiles to ensure you have a backup in case of mishaps.
http://support.2brightsparks.com/knowle ... 7-upgrades
You can download the latest version of Pro V8 from here:
If the problem persists, please submit a support zip with debug logs of the profile run for further investigation. Full instructions are given here:
