Hello
When I do a back up, SyncBack finds no files. But there are files in my OneDrive folders and I have to copy all again and again.
Why ? And How to change that ?
Regards
On OneDrive, SyncBack doesn't find the files
Re: On OneDrive, SyncBack doesn't find the files
Are you backing-up files to/from local OneDrive folder on Windows 10?
If yes, the problem is related to the recent OneDrive changes in Windows 10 fall creators update. Please un-tick the option "Ignore NTFS junction points (reparse points)" from:
Modify profile > Expert > Compare Options > Attribute settings page
and retry the profile run to see if it works?
Hello
No, it is not from this folder but from different folders on my W10 PC.
It seems to do not see the files on OneDrive.
I think I have made changes on my folders on onedrive.
When I start the profile, it shows 0 files but I have many files.
Please submit a support zip with debug logs of the profile run for further investigation.
