Old version (6.5.48.0) transferring files for no reason
NginUS
Post by NginUS »
Granted I'm on an older version, would like to resolve this rather than have to buy new just to get support.
I have a Windows 7 VM in VirtualBox with a read-only SAMBA share mirroring to AWS S3 daily. Some of the files it decides to upload shouldn't have changed in years, but there's regularly half a dozen of these being uploaded for no good reason.
I tried setting the timestamp offset to 60 seconds to see if it may be due to the VMs seconds being 0.5 behind- but did no good. The log is less than helpful with no verbose way to see what's really going on.
NginUS
Re: Old version (6.5.48.0) transferring files for no reason
Post by NginUS »
FYI, source directory stats are:
410.5 GB
200376 Files
25489 Sub-Directories
First, I suggest testing with SyncBackPro V8 release version (V8.5.62.0) to see if it helps. If the problem persists, submit a support zip with debug logs of the profile run for further investigation.
If you do not own a copy of SyncBackPro and wish to test its functions, you are welcome to try our fully functional SyncBackPro, which we offer a free 30-day evaluation.
NginUS
Post by NginUS »
I've installed the new version trial as suggested, and am now getting different errors regarding profile interruptions & as such am unable to determine if the original timestamp related error is resolved.
The first error I got was a 'failure to scan source', on a samba-shared resource, which I resolved by installing touch for windows & having a batch file run before the profile begins (using 'Programs - Before' option), that touches a file on the remote filesystem so that it's available to scan when it comes time to scan source.
Now I have an error saying "Failed to scan files: SQLite3 Error 10 - disk I/O error (FTP)"
Never had a problem with FastMail's FTP before, not sure how to proceed.
Please submit a support zip with debug logs to [email protected] for investigation
NginUS
Post by NginUS »
Swapna wrote:
Sun Jul 15, 2018 2:07 am
Done, thanks.
