Hi I have a problem
I just started using v7. got email log back and it has new meanings . i cannot find what the following 2 means can someone please help. Filtered (Source), Advanced setting
Thanks for any respone!
email log
Re: email log
Have you noticed ‘Filtered’ and ‘Advanced setting’ reasons in the Skipped section of the log file?
If yes, ‘Filtered’ means the file is skipped due to the inclusion/exclusion filters configured in the profile under: Modify profile > Simple > Change Filter settings page
‘Advanced setting’ means the file is skipped due to the Advanced settings configured in the profile. This KB article explains some of the Advanced settings configured in the profile:
http://support.2brightsparks.com/knowle ... ng-skipped
