Not showing Label in Alternatives after losing Admin Rights
ppack
Post by ppack »
Hi, I mount a container with Truecrypt to the drive letter R:\ I then rename the drive to "USB MC" using "F2" rename functionality of Windows explorer.
For some reason SyncbBackPro does not give me a LABEL alternative, only SERIAL NUMBER. I was expective Alternatives to give me "%LABEL = USB MC%
Troubleshooting steps:
I tried to dismount and re-mount the drive again with Truecrypt. Same result
I tried another mount option in Tryecrypt "Mount volume as removable medium". Same result.
-End of troubleshoot - failure.
So my question is: Why does SyncBackPro does not let me use LABEL as an alternative?
The only difference is that I created a new volume on my PC on which I do not have administrative rights anymore.
For the volume which I mounted and renamed while I had admin rights, SyckBackPro does show the LABEL alternative.
I am on Windows 7 Enterprise 6.1.7601 Service Pack 1 Build 7601
