Anybody try SyncBackPro 8 with pCloud? Any other version? It works with a small amount of data, but when I try a larger amount (> 10GB) the transfer dies. Errors are of the form "Failed to copy from <local folder name>: Cannot create folder <cloud folder name> (the system cannot find the path specified".
I'm trying the pCloud Sync tool now, then I'll break the sync, then trun on SyncBackPro again and hope it can maintain, but hope is a crappy strategy . I vastly prefer the flexibility and power of SyncBackPro to pCloud's tools.
