Ver. 8.5.62.0 32 bits
Hi.
I have set a few profiles to backup to a NAS Server and
I have set two profiles to backup to Google Drive (Gsuite) and authorized Syncback into GDrive
Both types of profiles works perfectly
Then I configured the "log to mail" options. I set it up to use a gmail account (The same as the GDrive storage) and authorized it
The problem is that the profiles that don´t backup to cloud work perfectly and send email logs.
But the profiles that backup to Google Drive can´t mail the logs. Trying to send mail manually with the "test email settings" button, it takes a long time and displays a 0x0000274c error.
Exactly the same setup, and only the to-cloud backup profiles fail. I did a lot of testing, authorizations, new accounts, etc etc.
Can anybody help please ??
Thanks a lot.
eMail log fails just on cloud profiles
Re: eMail log fails just on cloud profiles
I can't reproduce your problem. Can you please export the Google Drive profile (select the profile from SyncBackPro's main window > right click > Export Profile) and send your profile configuration to [email protected] for further investigation.
