Miror to multiple destinations
alexT
Post by alexT »
We brought a Synckback pro licence in order to miror our main server on multiple repository server.
I just want to know, if it's possible, to miror some folders to multiple destinations.
If not, can I duplicate profile and change only the destination computer ?
Re: Miror to multiple destinations
Sorry, but its not possible to backup files to multiple destination devices using a single profile. But, you can create a copy of the original profile (select the profile from SyncBackPro’s main-window > right click > select ‘Copy’ from the pop-up menu and give the copy a new name) and change the destination location as required.
alexT
Post by alexT »
Hello thanks for the reply.
But when i made change in the copied profile it also change the original profile..
Have you created Shared settings for any profile settings? Can you please export and send the original profile and ‘new copy’ of the profile (select the profile from SyncBackPro main-window > right click > select Export Profile from the pop-up menu) to [email protected] for investigation?
