I am using syncback pro v7, that's setup as group profile that runs – ever day at 07:00, and then repeats every 10 minutes indefinitely..
It should copy file sconti.exe from local partition of a disk to another – but for some reason the change in source file which in newer , is not recognized by syncback and the file is't copied to destination
The problem is somewhere in scheduled profile, when I run the same group profile manually, file is copied no problem, but when is run as automated task scheduled to repeat every 10 minutes, in history of that profile is that it didn't registered any changes and it simply skipped file.
How can i force it to register as changed file (i repeat as i manually start the same profile, the file is registered as changed)
- before testing i made sure that the file on the source has new date of modification)
Daily task with repeat interval of 10 minutes, doesn't detect changes
