Hello Everyone,
I had established a number of synchronizations between two remote sites a few years ago and the SyncBackPro product has been bullet proof since its application.
We are to be moving offices shortly and I have been advised that the Source QNAP will be relocated, but the FileSystem presenting the QNAP will not be relocated.
I have two questions ...
Will a FULL synchronization be performed if the Source Host is changed? (post relocation of Source QNAP datastore)
If the raw Source & Destination data are the same (from last previous sync prior relocation) should the synchronization be quite quick?
Any clarification would be greatly appreciated.
Thanks in advance.
