My Versioning is set to 2 versions, maximum of 0 days (ignoring the max setting).
I've been playing around with the number of versions to keep, coming down from 4 to 3 to 2.
Strange part is that the versioning *is* working for still existing files on Source, because I've seen the kept versions drop to 3 and 2 each manual run I do. But it completely ignores the versions (inside $SBV$) from non-existing source files. It seems as if these files are not registered in 'the system' ?! (not sure how SyncBackPro does its magic
Is there a way to do an automated clean up of the $SBV$ Versioning directories [if the source file doesn't exist, than delete the versioning file too] ?
Or make the system aware that these files are there and can be processed by the system ?
ps: running V7.12.12.0 (downloaded & installed today)
Thanks for the help.
Regards,
Steve
