BackBlaze B2 integration no longer works
sysut1
Post by sysut1 »
After much trial and error I have determined that BackBlaze B2 integration no longer works
Please help
Re: BackBlaze B2 integration no longer works
Please submit a support ticket to [email protected] with screenshots showing the problem for assistance.
sysut1
Post by sysut1 »
We released a new SyncBackPro V8 beta version to fix this issue. You can download and install V8 beta from here:
After upgrading run the profile to see if it works?
sysut1
Post by sysut1 »
I will let you know tomorrow when I am at my client site.
sysut1
Post by sysut1 »
Still testing
sysut1
Post by sysut1 »
Just sent you an email with error logs
Still having problems
Howard
