I use SyncBackPro to copy it from a csv file from an ftp server to a windows folder.
The problem is that I have another program that reads the files in the folder.
As a result, it happens that the file is not processed by my other program until it has finished downloading.
Is it possible to make syncbackpro modify the extension (example: file.tmp) and when the download is finished it returns the original one (.csv file)?
Thank you for your explanations.
Guillaume
rename a file during transfer
Re: rename a file during transfer
Sorry, but there is no option in SyncBack to rename a file on the FTP server before the transfer.
