Delete Empty Folders Except Root / Monitoring SFTP Path(s) for Changes
bzowk
Post by bzowk »
Hey Guys -
I'm testing out SyncBackPro and considering purchase if it can do what I need. So far, it is working well except for a couple of things I wanted to post about to hopefully get assistance, please. For the issues described below, I'm using profiles which all connect from a Windows system to a Linux host over SFTP. I'll try to explain the best I can... :)
Question #1: Deleting Empty Folders Except for Root Folder
Many of my profiles check a remote (SFTP) folder (usually remains empty) for new files/folders. If present, it moves (downloads) them to a local folder (which is not empty) then deletes the original content. When I first set these profiles up and new folders / files were added, it would Move / Download them as desired (one-way) but only delete the files - not the folders. I enabled the setting to delete empty folders in the profile, but since the root stays empty, it deletes it too!
Interestingly enough, the profile still succeeds at the next attempt despite the folder it is checking doesn't exist anymore. I am assuming that if the folder was recreated and content added it would operate as desired - however - the process that adds the content on the remote host fails without that folder remaining.
Example
Folder Setup
- Folder to Move From (Remote SFTP)
- /var/roothome/complete
- Folder to Move to (Windows)
- D:\Sync\Complete
First Profile Setup
If a folder named "Folder1" with the file "file1.abc" was added to "/var/roothome/complete" and the profile ran, it would move both the file and folder to "D:\Sync\Complete" but only delete file1.abc from SFTP. /var/roothome/complete/Folder1 would still be present
After Enabling "Delete Empty Folders"
After the profile runs, it deletes "/complete" from the host therefore the path "/var/roothome" does not contain a folder named "complete" anymore.
Question #2: Monitoring SFTP Path(s) for Changes as Profile Trigger
Obviously, there are a few options available for triggering a profile to run. One of those is monitoring a Windows path for changes. I do not see an option for monitoring for changes for a remote path, however; even though I know it's completely different. That being said, is there a way to do so? I am currently having each profile run every 30 seconds which is a pain as the content is added in the remote folders only 2-3 times a day however they occur at random times, can be lots of data, and are needing to be moved ASAP. If there isn't an option to directly do so within a profile, are there any workarounds using scripting, perhaps (assuming there is some sort of CLI for SyncBack Pro?)
To note, the Linux system hosting my source folders is local to the Windows system and runs Project Atomic (Fedora 28) which is basically a dedicated Docker host.
Any suggestions would be appreciated - Thank You!
Re: Delete Empty Folders Except Root / Monitoring SFTP Path(s) for Changes
Can you please submit a support ticket to [email protected] with your profile configuration for investigation.
Do not post (nor links to) profiles on this open forum.
