Dear,
We use the sharepoint connector to transfer some files from our local computer to SPO.
We configure everthing, find the site, find the library and start to copy files.
But in one file with .doc extesion, the software copy and remove the file and the process not stop.
To continue, we have to delete the file from Sharepoint.
It seems like from the appi, the document is new and remove and copy the document, and at the same moment compare with the local at seems that is new again.
A bug?
A document hangs on sharepoint
Re: A document hangs on sharepoint
Can you please generate/submit a support zip with debug logs of the profile run and the full path of the .doc file to [email protected] for investigation. Full instructions for creating and submitting the support zip are given here:
https://help.2brightsparks.com/support/ ... 3000335603
Do not post (nor links to) Support Zips on this open forum
