I am unable to setup Backblaze B2. I see other posts in the forum (most recent dated end of October) indicating that the integration is not working?
I tried setting up one job to point to an bucket I created. I have tried every combination of my Backblaze userid, Application ID, app-specific key, etc.etc. All result in a 401 cloud error.
It is possible that I am not doing this correctly - unfortunately there is nothing in the support site about it and the nomenclature in the Syncback configuration screens doesn't seem to match with Backblaze nomenclature. For example it asks for Application ID - yet, if you leave it blank it asks me to insert a valid user name (not application ID).
Any help would be appreciated. Thanks.
Cannot setup Backblaze B2
Re: Cannot setup Backblaze B2
Can you please submit a support ticket to [email protected] with screenshot showing the error message for investigation.
ok, done. Thanks.
Hi
I have the same problem so was the cause identified and a solution determined?
Thanks.
Thanks.
Hi,NewcastleBrown wrote: ↑Fri Dec 07, 2018 1:15 pmHi
Thanks.
At a guess, you might be using the wrong set of keys while attempting to list the buckets. Please review the following article to better understand how to setup your Backblaze keys with SyncBackPro.
https://help.2brightsparks.com/a/soluti ... 3000455546
In addition, if your Application key is NOT restricted to a single Bucket, then you should download/install the latest SyncBackPro beta version to resolve some issues. You can download the beta here:
http://www.2brightsparks.com/assets/sof ... _Setup.exe (Beta version 32-bit)
https://www.2brightsparks.com/assets/so ... _Setup.exe (Beta version 64-bit)
If you continue to have issues, please feel free to contact us again directly at [email protected] .
Regards,
