I have an extremely large folder of image files (2 million+).
I want to be able to Copy ONLY the ones needed currently to a web server.
So, can I just copy/sync using a text file, with the required filenames in it?
I am thinking about buying Syncback Pro, if this is possible.
Is it possible to backup ONLY a set list of files?
Re: Is it possible to backup ONLY a set list of files?
Hi, you can choose the files & folders to sync via selection and/or using filters, e.g. *.png files only. If you really need the decision to be based on a list in a text file then you'll need to use scripting in SyncBackPro.
