Hello everyone
Is there a way to get SyncBackPro to prompt/ask me for the value of a profile variable every time the profile is run? I'm trying to set up a profile which allows me to choose a folder under a defined path to sync (without changing settings each time).
The use case is to allow me to copy a subset of my photos to/from my laptop (as there isn't space for all of them), where the subset to copy will change depending on what I'm working on.
Thanks.
Prompt for variable value on profile start
Re: Prompt for variable value on profile start
Hi, you can pass the source and/or destination directories to use via the command line (see -source and -dest in the Command Line Parameters section of the help file). So one option would be to create a batch file that prompts you and then runs SyncBackPro using those supplied directories:
Note the above assume you are using 64-bit SyncBackPro and that your profile is called myprofle (change as appropriate). Save it to a batch file, e.g. myprofile.bat, on your desktop. Then just double-click it to run it and be prompted for the directories.
Code: Select all
@echo off
set /p source="Enter source directory: "
set /p dest="Enter destination directory: "
"C:\Program Files\2BrightSparks\SyncBackPro\SyncBackPro.exe" -source %source% -dest %dest% myprofile
Hi, you could also/instead set up the (or 'a') profile to use the Windows Shell Extension that comes with Pro (only), so that you could right-click a folder or drive in File Explorer and specify which profile to use to 'feed' the contents of the folder/drive you selected to a Destination. This destination can either be hard-wired (in the profile) or it can be prompted for after the right-click (the response to the prompt then overrides the 'wired' Destination)
viewtopic.php?f=15&t=13450
viewtopic.php?f=15&t=12618&
