OneDrive integration failing due to deprecated API
dchitwood3
Post by dchitwood3 »
I'm running SyncBackPro v7.12.12.0 on Windows 10 64-bit. I've had it configured for sometime to backup a local drive to my Microsoft OneDrive. The last successful run was on 1/5/2019. The run from 1/12/2019 failed with the following error:
Failed to prepare OneDrive : api_deprecated: This API is no longer supported. Please see https://aka.ms/livesdkmigration for information about migrating your application to Microsoft Graph.
It seems that Microsoft blocked the API being used by this version of the software. The Microsoft site referenced indicates that the was to stop working on 11/1/2018. So, I'm glad they didn't immediately pull it but it appears to be down now.
I have 2 questions:
1) Any chance that 2BrightSparks patched v7 before ending support? If so, is there a download site?
2) If I need to buy a new version, does the latest version of SyncBackPro v8 support the new API?
Re: OneDrive integration failing due to deprecated API
You need to use the new OneDrive's API supported in SyncBackPro V8 to resolve your issue. Please submit a support ticket to [email protected] for the instructions to change your profile configuration to new OneDrive's API.
dchitwood3
Thanks Swapna. Based upon that reply, I'm assuming that v7 is now useless for talking with the OneDrive cloud now but it does work with v8.
