it is possible to disable a SB-Profile and the the corresponding windows-task only with the SB-GUI (enable/disable profile)? I think if someone disable the sb-profile, he want´s also to stop the corresponding windows task.
Disable SB-Profiles and Windows Tasks
Re: Disable SB-Profiles and Windows Tasks
Sorry, not possible. However, I will pass your request to the relevant department.
