I think we have a chicken & egg problem ... There seems to be no way to get to Cloud > Advanced as the profile has to be saved first, and I cant save the profile because it says I need to select a bucket, but that's when I get the SSL error.
I managed to get to the Profile Setup window with the Expert option in the left menu by filling in S3 settings and hitting Done, but then I cant click Expert because of the same "You must select a cloud bucket/container" message.
If I temporarily uncheck "Amazon S3 files are on a cloud storage server" , I can then go to Expert>Cloud>Advanced, but since I unchecked the S3 box all the settings are greyed out.
- snip1.JPG (19.12 KiB) Viewed 3450 times
If I put the check back in the S3 box, I cannot get back to "Advanced" because of the "must select a bucker" message.
- snip2.JPG (37.85 KiB) Viewed 3450 times
