Is there a way to automate the comparison such that if the file size is the same you want to skip copying over the file?
I have a backup where the dates of all the files have been changed (bad job, BackBlaze!). I am restoring from backup but where there are collisions and that is due just to file date change, I want to skip the restore and over-write if the file size is identical.
Thanks!!
Skip if file size the same
Re: Skip if file size the same
Can you please export and send your profile configuration to [email protected] for assistance.
