Confused not backing up everything?
OK so I have been using Robocopy for years but the newest version of that software sends a useless log file to me. So I broke down and bought Syncback Pro. I have had nothing but problems using this software? I read people saying they have been using it for years no problem? So I must definitely be doing something wrong? Here is the setup on my work network. Source = \\Servername\Public Destination = \\Servername\servername {folder}. I tried this and it scanned and only found like 93 files to backup and there is probably close to a terabyte of data in three folders on the source? I selected backup and did a simple setup for the profile. The only thing I did modify is I told it that the source was a Syncback Touch device and that tested fine. Now the destination is a brand new RAID 10 array on a new server I rebuilt which was empty and ready to accept data but when the profile runs after scanning it states there are only 93 files to backup? To be completely open I did have this configured to run last night as a group to backup two different sources but that failed miserably so I deleted those profiles and started over again with pretty much the same result? I have been doing this stuff for quite a few years and normally don't have difficulty with new software but this is frustrating me to no end?
Re: Confused not backing up everything?
Can you please generate/submit a support zip with debug logs of the scan phase to [email protected] for further investigation. To do this, enable 'Output debug information' from Preferences menu and run the profile in manual mode (ctrl + R). When the Differences Window is displayed abort the profile run and submit the support zip as per the instructions given here:
https://help.2brightsparks.com/support/ ... 3000335603
Swapna,
I did as you asked and I have uploaded the debug log file to your FTP server named NHDC1.zip.
As requested, can you please send a support ticket to [email protected] for further assistance.
