Hi, have you checked the notification area in the bottom-right corner of your screen?
hi
about windows 10 banner on the bottom right of the corner ,yes , it doesn't appear
might you please post a screenshot of the syncbackpro notification?
thanks
Hi, after running a profile, and the Differences window appears, a "toast" message will briefly appear at the bottom-right on the screen. After it has gone, if you click on the notification icon at the bottom right, then it will show something like this:
(ignore it saying SyncBackSE at the top and SyncBackPro below, I'm running a development version).
Despite the misleading text, it actually only does this when it's waiting for your input, not when it actually starts running.
hi
i have the last portable version , but no windows 10 toaster
don't know why...
thanks
