When I start several profiles at the same time SBP starts the profiles, but at the same time it shows a message telling me that the profile is already running. This message is displayed for each individual profile.
Very annoying.
I was forced to reinstall the previous version 8.6.6.3.
Bug: Profile already running (version 8.6.7.6)
Re: Bug: Profile already running (version 8.6.7.6)
The error 'The Profile is already running or is due to run' suggests that the previous instance of a profile was still running or haven't closed before a new instance of SyncBackPro was called to execute the same profile. In such cases, SyncBack aborts the profile run to avoid collisions. Can you please export and send profiles that are causing this issue to [email protected] for investigation?
It's impossible, because I was selected two profiles in the list and press Run button.
Next I have selected several profiles (5 or 6) and after press Run button several messages have appeared in sequence.
Next week I re-install 8.6.7.6 version, try again, and send you profiles.Swapna wrote: ↑Fri May 31, 2019 10:18 amCan you please export and send profiles that are causing this issue to [email protected] for investigation?
This is the profiles both runs.
Image shows the problem.
Please do not post (nor links to) Support Zips on this open forum. Please submit a support ticket to [email protected] for investigation
Ok, I will send to support.
Thanks.
Thanks.
