Main window resize bug
- Knowledgeable
Attempting to reduce the height of the main window beyond its minimum results in the window moving down in the Y direction. Re-expaning the height then shifts the window back up. See screen capture: https://drive.google.com/file/d/1ITClHw ... LSddH/view
- Knowledgeable
Re: Main window resize bug
Hi, I couldn't get the video to play unfortunately.
- Knowledgeable
The first link is broken, not sure why the second one is not working.
GIF capture:
GIF capture:
- Knowledgeable
Hi, sorry, I can't reproduce this. For me, the window does move down when it reaches it's minimum height, but expanding it works fine. We're currently working very hard on the next release which will have the option to switch off themes. It appears themes are the cause of it moving down once reaching minimum height, so hopefully it would fix this issue. Thanks
